Old 08-16-2014, 12:03 AM
itk96 itk96 is offline
Default RV-8 Wing tank fuel senders
I am in the process of building the fuel tanks on the RV8. I initially ordered the resistive type fuel senders (float type) with the kit. I would like to switch to the capacitive plate fuel senders. I was told by vans that they no longer sell the capacitive kit. I am putting the flop tubes in both tanks and am looking for options other than installing the float type on the rear baffle in the second bay. Any thoughts or ideas?
Old 08-16-2014, 01:14 AM
moodyjr moodyjr is offline
Option 1 - get the Princeton Fuel Probes from ACS -should be able to install them in the root rib with the probe clear of the flop tube
Option 2 - It would be easy enough to make your own plate sender kit - get drg OP-7 from Vans for the details - the plates are ex 025 sheet, some nylon spacers, std AN hardware & readily available BNC connectors. The signal converters are available from Princeton Electronics
Old 08-16-2014, 06:30 AM
tweiss's Avatar
tweiss tweiss is offline
itk96,
I was in your shoes earlier this year when I posted the same question here. I got lots of great advise and fortunately I was able to get my hands on one of the last capacitive plate kits from Van's.
As moodyjr pointed out, fabricating your own sending unit plates would be simple to do.
Here's the link from when I asked the question last Feb.
http://www.vansairforce.com/communit...d.php?t=110261
Tom
Qualified Exempt
But dues paid anyway 2014
RV-8
SB wings in progress
Tail kit complete
Old 08-16-2014, 07:09 AM
billdianne's Avatar
billdianne billdianne is offline
I have a complete capacitive kit that I didn't use. PM me with your address and I'll send it to you.
Bill
RV-8
Old 08-16-2014, 07:47 AM
rv7charlie rv7charlie is offline
If you ever expect to use mogas or ethanol laced gas in the future, be aware that capacitive sensors will have significantly different calibration between avgas and E-gas; and some difference (can't remember how much) between avgas & no-E mogas. That's what kept me from using them in my build.
Charlie
Old 08-16-2014, 08:44 AM
Thank you Bill. What a great community. Just a few hours and I have all my problems solved.
