Old 08-14-2014, 11:45 AM
mill2978's Avatar
mill2978 mill2978 is offline
Default Primer over internal rivets?
I purchased my wing kit from someone who had already assembled the rear spar, they primed it ( I think Mar-Hyde), I've been using a different primer and would like it all to match. Assuming I can prep the current primer in a way that the new primer will stick is there any reason not to spray over the already set rivets? Would I lose any level of inspect-ability? Painting over the rivets on the outside of the plane is the norm, I just haven't seen rivets on the inside covered up.
thanks
Aaron
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 08-14-2014, 01:31 PM
paul mosher
Posts: n/a
Default sure
I seen biz jets with so much paint you can't even see the rivets. No reason not to prime over shop heads except for additional weight.
Old 08-14-2014, 01:50 PM
larrynew's Avatar
larrynew larrynew is offline
As far as getting primer to stick over rattle can primer, I did an informal test of Sherwin Williams G60P2 Wash Primer over NAPA 7220 self-etching primer. The G60P2 was just as difficult to scratch and scuff over the NAPA primer as the scuffed bare metal. It has stuck hard to everything I've sprayed, dries fast and Van's likes it.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
