Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 08-14-2014, 10:05 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default GNS 430 Does not read data card
I recently put a current data card in my non-WAAS Garmin 430 and it will not read the card. Put the old card back in and it won't read that either? Any ideas out there?
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 08-15-2014, 08:07 AM
AlexPeterson's Avatar
You likely did this, but perhaps blow some air (from the little cans) in there? If you are lucky, it is just a piece of debris. I've had to re-seat cards more than a few times. Also re-seat the terrain card if so equipped. I had that cause a mis-read on the aviation data card during boot up for some reason. Good luck!
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 08-15-2014, 11:08 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Just had same issue with most recent update
Would not read the card, but would read the old card ---- maybe the latest update was a problem? A new update is coming up, so, we will see. I will try to update the same card.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 08-15-2014, 04:29 PM
ronschreck's Avatar
Default Got it!
Turned out to bea bad card.
Ron Schreck
IAC National Judge
VAF 2021 Donor
Old 08-16-2014, 06:15 AM
turbo's Avatar
turbo turbo is offline
good news, i have had one card die on me over all the years. i always carry a spare on long trips with prior months data. its good to pick one up when they come by cheap.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
