Old 08-11-2014, 03:49 PM
g zero g zero is offline
Default Alternator Wire Size
Did some searching on the forums ,looks like 6awg wire is the prefered wire from the alternator , looks awful big ! Is a 6 wire overkill ?
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 08-11-2014, 03:52 PM
joe1968 joe1968 is offline
nope its the recommended sizing, check the aeroelectric website
Old 08-11-2014, 04:56 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
40 amp or less alternator and 8 gauge is sufficient IMHO,
50 amps or higher alternator, use the larger wire for the B-lead.
This is for 12v systems. Nobody builds RVs with 24v electrical systems, else you could use smaller gauge wire
Neal Howard
Airplaneless once again...
Old 08-11-2014, 07:05 PM
SmilingJack's Avatar
Yup. I used 6ga.
John Mastro
RV-8
Old 08-11-2014, 08:37 PM
Walt's Avatar
Walt Walt is offline
The way I read the chart is:
A 6ga wire can handle 70 amps continuous at 15 ft.
A 8ga wire can handle 70 amps continuous for 10'
A 10ga wire can handle 70 amps for 5.5'
Being that a more realistic length for the the 'B' lead in an RV is 3-4 ft and it generally will be less than 40 amps, you could really use 12 ga wire which is good for 50 amps continuous at 5' according to the bible (43-13, Chp 11, fig 11-2)
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-12-2014, 12:18 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Voltage drops
Those are current handling numbers for a 1/2 volt voltage drop.
Depending on the way your Voltage Regulator is set up and where it's sensing location is, this 1/2 volt drop may not be good since this wire is a direct part of the charging system
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-12-2014, 04:52 AM
Walt's Avatar
Which happens to be one of the reasons I prefer the externally regulated B&C unit to the PP as it actually senses bus voltage as compared to voltage at the alt like the PP unit.
My point was mainly that a 6ga wire is overkill for most RV's with a short 'B' lead and current draws that likely average under 25 amps with a fully charged battery.
Old 08-12-2014, 08:24 AM
Mich48041 Mich48041 is offline
The voltage drop is only one consideration. A safety consideration is the temperature of the wire at continuous load. Wires in a bundle need to be larger because they can not dissipate the heat as easily.
AC 43.13-1B TABLE 11-9 gives the ampacity of different wire sizes. 12 AWG is rated between 13 and 25 amps, depending on the temperature rating of the insulation. A #12 AWG wire carrying 40 amps will be too hot to hang onto.
Joe Gores
Old 08-12-2014, 01:40 PM
rapid_ascent rapid_ascent is offline
Voltage drop is power lost even if an the regulator can compensate for it. I always vote for lower voltage drop if it can be accomplished without too much of a weight sacrifice. In this case the currents are high so the power loss is high (Power = Current * Current * Resistance) so I would go with the more conservative wire size.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-12-2014, 01:49 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
May I suggest that you up-size to the next larger wire, just in case you end up changing the alternator in the future??
These planes are becoming more and more loaded with electronic dodads, and it never hurts to plan ahead.
The weight gains is almost nil..............
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
