10-10-2006, 12:07 PM
rivet high vs flat margin
Does anyone else find that on some rivets the margin between a rivet being too high and being too flat (according to the rivet gauge) is almost nonexistent? For example, I find that on some of the empennage skin-to-rib rivets, when I use my pneumatic squeezer with some number of washers the rivets are just a smidgen too flat (over-squeezed) according to the rivet gauge. But if I take just one washer out of the squeezer, they come out under-set (again according to the rivet gauge). In these cases I err on the side of slightly over-setting the rivet.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-10-2006, 12:12 PM
Phil-
You will really want to get an adjustable set for your squeezer. It is much quicker and will allow a much more precise setting. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
10-10-2006, 12:23 PM
I agree with Steve. I worked with the washers for the entire empennage. What a pain! I broke down and spent the $70 or whatever for the adjustable, and never looked back. IT IS WORTH THE DOUGH!!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
10-10-2006, 12:28 PM
now it's just a matter of finding the right adjustable set for my squeezer... I'll look at my squeezer documentation when I get home and maybe you guys can recommend a good one for me...
Phil
RV9A (SB)
Ottawa, Canada
10-10-2006, 12:31 PM
I think they are all pretty much standard. If you have the 214 style squeezer, the ones from Cleveland, Avery, The Yard, etc...work.
Chad Jensen
10-10-2006, 12:41 PM
Use a thin washer instead of, or along with, a regular washer to get that smidgen!
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
10-10-2006, 01:09 PM
Mine Came with different washers
My squeezer came with a set of washers with different thicknesses.
I spent about 25 rivets worth of time changing them to get the right stackup and then had enough and called Avery for an adjustable set holder. Never looked back.
Call Avery and tell them what you have and they will hook you up with the right adjustable set holder for your unit.
10-10-2006, 02:07 PM
Originally Posted by prkaye
.....I find that on some of the empennage skin-to-rib rivets, when I use my pneumatic squeezer with some number of washers the rivets are just a smidgen too flat......if I take just one washer out of the squeezer, they come out under-set......
Use a combination of thick and thin steel washers as required.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
10-10-2006, 02:45 PM
Or use the correct parts....
Or you could use the correct shims made for the job.....
http://www.usatco.com/squeezer_sets_25.asp
They come as thin as 1/64 thick (half of a thin AN washer), and note that they have a bevelled edge on one side. This helps the shim sit correctly since the "pin" to rivet set body is not a sharp corner.... it is radiused for strength.
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
10-10-2006, 03:21 PM
Oversmashing is better than under-smashing
In the end, I wouldn't drill out those rivets just because they are a tad oversmashed. Now if they are WAY oversmashed, then I'd consider replacement. If you have to err on one side or the other, err on the side of over-smashing.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
