Hello
I have a dual PMAG setup on my IO-320 / RV-7A. It is time to route the ignition wires now, but then, a important question pop up:
How to layout the ignition system?
Version 1: L = 4x top / R = 4x bottom
The left PMAG ignite the top plugs.
The right PMAG ignite the bottom plugs.
Version 2: L = 2x L-bottom;2x R-top / R = 2x L-top;2x R-bottom
The left PMAG ignite two bottom plugs on the left an two top plugs on the right.
The right PMAG ignite two top plugs on the left and two bottom plugs on the right.
Version 1 will give more drop difference during a run up check.
Version 1 will look "cleaner and easyer on paper (in my mind too
Version 2 will have a more "symetricaly" drop in a run up check.
Due to this, Version 2 will be more easy to detect a failure/bad plug/bad nozzle.
I think both versions would be ok, but:
Which version is better? Which version should I build?
I will also contact Brad at EMAG-Air with this.
Thanks for any input!
