Old 08-06-2014, 07:47 PM
xCountry22 xCountry22 is offline
Default Where do I find OP 46-02??
My wing instructions refer to the stall system wiring run and says:
See OP46-02 Step 8 and OP46-02 Figure 3.
I am clueless. Where is this?
And this happens just when I thought I might be finally getting a clue on this airplane building thing.
RV-7
Slow and steady.
Old 08-06-2014, 08:06 PM
BillL BillL is offline
Just call Vans early in the morning and ask for them to send this dwg to you in .PDF form. Get it in 3 min via email.
You can zoom, cut and print the section you want.
For future reference, you might order the whole list of drawings on disk. That way you will definitely have all OP's
Bill
RV-7
Lord Kelvin:
Old 08-06-2014, 08:31 PM
Thanks.
BTW, I recently received the new CD with the RV7 plans and DWG 46 is not listed in the CD's OP section. Wonder why.
RV-7
Slow and steady.
Old 08-06-2014, 08:54 PM
wirejock's Avatar
wirejock wirejock is offline
Default OP plans
The OP plans should have been in the stall warning kit. I have them if you don't get them, send me an e-mail. I will scan them and reply with the file.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-29-2016, 08:17 AM
StuBob StuBob is offline
Reviving an old thread for a clarification:
Do I understand correctly that OP46-02 comes with the stall warning kit, not the wing kit?
Stu F.
RV8
Old 02-29-2016, 08:25 AM
wirejock's Avatar
Default OP plans
Correct. Several subsystems come that way.
Larry Larson
Estes Park, CO
Disclaimer
Old 02-29-2016, 09:09 AM
rvbuilder2002's Avatar
A drawing designation of OP means it is related to an optional kit and not included with the regular kit plans.
Scott McDaniels
Hubbard, Oregon
Old 02-29-2016, 09:31 AM
AHA!!!
I never would've figured that out.
Of course, it took me some time to figure out that "PP" meant "pre-punched," not "post-partum!"
Stu F.
RV8
