Originally Posted by ron sterba
I mounted my transponder antenna 4" aft of the firewall and 3" in from left side behind pedals. Keeping it at least 2 feet from ADS-b which is located 6" front of the wing spar and under the right gear weldment & about 7" from the fuselage side. I have a floor in mine with sound proofing with 90 degree B & C connectors at both antennas.. Also I Alodined both the skin and doubler plate.
Ron in Oregon RV9A
I located my transponder just aft of the firewall too. Also the second one (ads-b i think) is close to the pitch servo so it would be well clear of the coms which are just aft of the spar.
Unsolicited info: On the coms, I mounted them so the front screws go into the spar flange. I don't recommend this location. The underside overlaps the heavy forward fuse skin and results in a step there. I would place it about 6-8" aft if i were to do it again. Back far enough to clear the control rods.
Bill
RV-7
Lord Kelvin:
