Old 10-09-2006, 12:10 PM
mark schoening's Avatar
mark schoening mark schoening is offline
Default !%$#(*&^%$--ah--does anybody use bondo?
OK--I'm a klutz! on tail, flush set slipped and I now have small dent next to rivit. Wait to paint time or ? I can't think of a fix.
Old 10-09-2006, 12:18 PM
PainterJohn PainterJohn is offline
Banned
Your best bet to fill that ding is to use a good body filler not "Bondo" brand but use Evercoat or 3M body fillers. Pirana and Icing putties or surface glaze is not for filling dings, only pinholes in fiberglass or in other minor imperfections. Most automotive paint supply places carry the good stuff. AutoZone does not (well in my area). All of the "heavy" fillers work best (and should always be applied) to bare metal, besure to sand the area with atleast 80 grit before you wipe it on there, otherwise it will flake later on.
Good luck
John
Old 10-09-2006, 12:20 PM
Mel's Avatar
Mel Mel is offline
Bondo is heavy. More modern fillers use microballoons. Just leave it for now and catch them all just before paint. There will be more.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-09-2006, 12:39 PM
OK, thanks for info, guess I'll store the piece so nobody can see the ding and deal with it at paint time. "there'll be more---???" urgh
Old 10-09-2006, 01:01 PM
frankh's Avatar
frankh frankh is offline
Default More?
Some fly before paint and some paint before fly.....Now you know why.....
Frank
7a painted before flight.
Old 10-09-2006, 06:24 PM
szicree szicree is offline
I don't know that there is any agreement on whether to prime first. A lot of auto guys swear by epoxy first, then fill. To each his own, I guess.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-09-2006, 08:53 PM
TSwezey TSwezey is offline
I repair my dings right away! I hate looking at the stupid things! Also, you might forget where they all are and you will find it after its painted! You will probably make some more dings!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 10-09-2006, 09:26 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
If you fill it make sure you sand the area your working on REAL good. Most RVs that I have worked on that have had some type of fill work done to them have not been sanded well. Not sanding correctly will lead to the body filler popping off. I would suggest machine sanding with something in the range of 36 to 100 grit.
Funny story. I had a customer one time insist on me using "aero-dynamic filler" on his plane. I was also instucted to purchase said filler from Cessna. For $100 Cessna sent me 1qt of DYNA-LITE. DYNA-LITE is exactly the same as BONDO. Made by the same company only a different label on the can. I could have purchased the same can of filler at the local auto body supply for $10.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 10-09-2006, 10:21 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Be Careful
Be careful here!
This is where an auto body guy can ruin your plane. In general, the FAA only allows 10% reduction in skin thickness to remain airworthy.
An enthusiastic (but well meaning) auto body guy used to working with steel can easily remove 0.0025 inch of your aluminum skins, especially with 36 or 50 grit sanding disks. Add some power tools.....
I talked to my aircraft paint shop recently about hail damage repair (another Tiger... not mine) and he said it was more expensive because they strip, and then prime, and then fill. This way, when they sand the filler smooth they can see if they are sanding through the primer layer and taking metal off. Hail damage is similar to the dings we are talking about here, perhaps shallower - he said 0.020 to 0.030 inches deep on average.
Care is needed here with the aluminum - part of the reason aircraft paint shops charge more...
Gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-10-2006, 03:05 PM
KTM520guy's Avatar
Yes, you do have to be very careful. You want to get past the point of being lightly scuffed but stop well before the point of sanding a thin spot in your skin. Using tools like die grinders and disc sanders is a good way ruin a good skin panel. Use a DA (dual action) sander for best results.
RV-8A builder
A&P mechanic
