  #11
Old 08-03-2014, 12:36 PM
roger lee roger lee is offline
I guess I'm going to have to change my particular language terms when I describe this from now on. (no silicone)
Roger Lee
Tucson, AZ
Old 08-03-2014, 04:10 PM
rgmwa rgmwa is offline
Originally Posted by Peterk View Post
Robert! I'm guessing silicone has yet to be invented in Austrailia? hahaha (or have you all discovered something better!)
Don't know what they have in Austrailia, Pete, but here in Australia we have plenty of silicone, and even more silicon. The outback is full of the stuff!
•INOX-mx3 contains no silicon, acid, kerosene or dieseline
Yep, that's what the ad says Roger. No silicon .... makes it too gritty.
Probably hasn't got any silicone in it either.
rgmwa
RV-12LR 912ULS
120346
Old 08-03-2014, 07:40 PM
edsong's Avatar
edsong edsong is offline
Default Lube
LPS 1. That's it.
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 08-03-2014, 11:44 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default AeroShell Grease 33
I am going to use AeroShell Grease 33 for most of my airframe parts which have to be lubricated. It's an universal airframe grease and highly corrosion protective.
However, from their specs. I can't tell whether it contains Silicone.
http://www.shell.com/global/products...grease-33.html
They claim: "Of 359 grease application points on a Boeing 737 - AeroShell Grease 33 lubricates all but 9 of them"
So, what is good for Boeing and Co. can't be that bad for my little RV.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 08-04-2014, 05:45 AM
bobnoffs bobnoffs is offline
i brought up the silicone thing because i had read that the property that makes it so desireable [adheres well] also makes it show up in places that were handled long after. i got the impression normal stuff to remove oil won't touch silicone.
ideally the oil is thin so capillary action takes it into the fitting and the lubricant doesn't dry out.
as my current plane is wood and cloth i probably am more careful about getting oil on other places besides the fitting. like i said before a hypodermic needle gets in really tight places with no ''overspray''.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
