Help debug Garmin 327 / AK-350...
I had my airworthiness inspection scheduled and then found out that my transponder was not sending pressure altitude. It is sending transponder code and everything else appears to be correct. Had to cancel the inspection. The FAA inspector did not want to come out until it was fixed.
I'm trying to figure out how to diagnose the problem. The wire harness for my transponder/encoder was made by SteinAir. I sent them my encoder and transponder so that they could verify everything was working. Of course that was a couple of years ago.
I had the data correspondence check done by the local FBO a few weeks ago. I took over my altimeter and encoder for that test. Everything checked out.
I've verify that the encoder is getting power and gnd on the right pins, from the harness.
My understanding is that the AK-350 is not an RS-232 device, but that it sends data over the grey code pins.
I've gone into the configuration section of the transponder. There is a section for configuring the two RS-232 channels. One is set OFF, the other is set ICARUS ALT. But I assume it doesn't matter since the AK-350 is a grey code device. Just in case I tried setting the other channel OFF also. It didn't help.
There is also a "Gray Code Input Page". You can't set any options, but it shows the code coming from the encoder for debugging purposes. The code is all zeros. (00000000000) This is supposed to be the binary representation of the altitude sent by the encoder. So obviously the transponder, for some reason is not getting the altitude.
So, I'm not sure what to do next. I'd appreciate any suggestions. Aircraft Spruce sells test devices that emulates both the encoder and the transponder so that you can figure out exactly what the problem is. It is $300 though.
Since it was working for Stein, I'm just wondering if there is something obvious that might be wrong.
Thanks for any help,
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
