08-01-2014, 10:10 PM
Question about capacitive fuel senders
So I'm working on my left tank now, and tonight I pulled out the instructions for the capacitive sender to review before getting started. I was surprised to see that there's only one wire, which connects to both plates and then to the connector on the inboard rib.
I guess I'd assumed that with two plates in the tank, those two plates would act as the two plates for the capacitor, but obviously that's wrong. I guess the tank structure acts as the second plate, with the outer portion of the connector making direct contact with the rib?
This isn't make-or-break information or anything; I trust the instructions are correct. But I'm a curious guy, and I like to know how things work.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
08-02-2014, 12:59 AM
The reason there is only 1 wire is because the two plates are connected together in parallel. Total capacitance is a function of the plate area. The other side of the capacitor is actually the rib/skin of the tank. The BNC connector connects the skin to the outer connection of the connector, while the wire is the center conductor of the connector.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
08-02-2014, 06:11 AM
Ray is spot on. Plates are one side of the capacitor and the rib is the other.
On a different subject, I want to make sure you know a tip about sealing the BNC. Fuel can wick through the stranded wire, under the sheath and through the BNC connector and ultimately out of the tank. (So I have heard) The tip is to cover all of the wire connections with proseal for a couple of inches up the wires. I did. No leaks.
Bill Pendergrass
ME/AE '82
08-02-2014, 08:56 AM
Sealing wire
+1
Seal the other ends and connections as well.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
08-02-2014, 09:21 AM
Good info. Thanks guy, my curiosity is satisfied. Back to work...
Philip
