Old 07-31-2014, 02:32 PM
Paul 5r4 Paul 5r4 is offline
Default CHT with PTT push issure
While flying the other day something happened that's new for me. I pushed the PTT switch to make a routine position report and the #4 CHT which had been 350 shot up to 800. As soon as I released the ptt switch it went back to normal. Only affecting the # 4 CHT, the other 3 remained normal. It must be picking up something from the radio somehow... I'm thinking like a short or something? I'm still able to transmit when broadcasting because no one has complained and have verified when I'm transmitting I'm getting out fine. Must be something isolated to the "reception" in the #4CHT wire from the cylinder. The reading is rock solid long as I don't transmit. Any suggestions on where to start looking?
Thanks in advance!
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 07-31-2014, 04:04 PM
Paul - this is very typical of "radio frequency interference" (RFI). When you key up the transmitter you're sending RF energy down the coax cable. While we like to think of coax cable as being completely effective at keeping all that energy inside the cable, the truth is just the opposite - braided shielding is a bit more like a fine sieve than a Faraday cage. Some of that RF energy DOES escape.
Escaped RF energy is likely coupling into adjacent wiring bundles, perhaps the bundle that contains your CHT wires.
The fix for this kind of RFI (assuming this is a newly occurring problem in an installation that's been flying trouble-free for some time) is usually a simple "assume the position" under the instrument panel and trace the coax from the COMM radio. Anywhere it comes close to another wire bundle, do your best to achieve separation. If you can alter the direction of bundles so they cross as close to perpendicular as possible that likewise will be better.
After about 15 minutes of standing on your head and judiciously applying zip ties I bet you'll find your problem is solved.
One "gotcha"... Coax cables "leak" more energy when the antenna isn't able to absorb all that energy. Do a good check on your antenna - make sure it's grounded, make sure your coax connection is clean and tight, and don't forget to ensure the centre pin of the BNC connector is actually attached to the centre conductor of the coax. This will help you rule out the antenna connection as an exacerbating factor.
Old 07-31-2014, 04:51 PM
bruceh's Avatar
bruceh bruceh is offline
I had this issue with my Dynon Skyview EMS unit on all of my CHT's and EGT's. There is additional shielding for the EMI that can be done by the factory, so I sent back the unit for the fix. The upgraded unit solved my issue with the temperature spikes while transmitting.
If you don't have a Dynon EMS unit, you can still get some Dsub connector capacative filters that can be installed. Search google for
site:L-com.com DGFC9MF DGFC37MF
http://www.l-com.com/d-sub-slimline-...e-unwanted-emi
Bruce Hill
2020 VAF donator
