07-30-2014, 12:24 PM
Originally Posted by bhassel
Try Boelube if it's really tight to get the screw into the nutplate.
Bob
That's a good technique every time for the first use of a screw into a new nutplate.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
07-30-2014, 07:44 PM
Washer stacks work and I used that technique sometimes but I also had a supply of 1/4 inch long phillips head #8 screws. I preferred them over the washer stacks.
Bill Pendergrass
ME/AE '82
07-30-2014, 08:19 PM
This is okay but you should paint all the heads orange so you don't leave them there by mistake. Otoh a stack of washers is hard to miss.
07-30-2014, 08:53 PM
Originally Posted by az_gila
The prevailing torque is the only requirement I found in several Mil Specs I checked. I could find no use limit numbers...
It is a material specification. Just as the surface finish, hole diameter, material, rivet hole dimension, etc.
The product must "meet or exceed" X cycles and retain run on torque....
Similar to the TBO on a Lycoming, if you can get more out of it, that's great!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
07-30-2014, 09:18 PM
By accident I found that the nut plate AND the screw wear in with cycles. I noticed that the hardware store stainless #6, #8 screws wear in pretty quickly. Then using a proper aviation screw the install friction torque jumps significantly.
You might experiment with this to get a better feel for it.
Bill
RV-7
Lord Kelvin:
07-30-2014, 10:44 PM
The older MS21047 specs do not seem to have any usage requirements -
http://www.everyspec.com/MS-Specs/MS...47F.034285.pdf
Did they add them when they became SAE specs?
Or are you referring to later, fancier, more expensive nutplates than we typically use?
The MS21047 -
http://aircraftfast.com/thumb.php?im...IF&w=300&h=300
Gil Alexander
07-31-2014, 04:28 AM
Thats true. In my case they were commercial grade. Not sure what finish (possibly black oxide) but they were easily different than cad plated screws.
Bill Pendergrass
ME/AE '82
07-31-2014, 08:21 PM
I've never seen any reference to nutplate replacement after x cycles, in 20 years of both .civ and .mil helicopter maintenance, on multiple models from every "major" helicopter OEM (except the Russian OEMs). Plenty of references to loss of run-on torque, prevailing torque, and locking ability... but never "replace nutplates after x remove/install cycles".
Nutplates are an "on-condition" item, just like common panel hardware.
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
07-31-2014, 08:31 PM
fiber
I think they are confusing fiber lock nuts with metal nutplates.
08-01-2014, 09:26 AM
Yes, they are "on condition"...
Yes, there is a material specification that states the nut plate must meet or exceed xx cycles. Don't confuse this "minimum specification" with a "recommended replacement schedule". If they meet run on torque, they are serviceable.
...but the point remains they do wear out eventually. We replace them by the thousands in depot.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
