inspections
During the last 6 yrs of crewing helicopters.... vibration was a daily item... We all used the torque stripe extensively... yes I know it's a green helicopter but a little flourescent orange goes a long way inside the tail boom or other critical areas... The last condition inspection I did was on a -4 and it turned up wear on the flap push rods and wear on the motor mount/oil dipstick... and a few other items too. I like threadlock and locknuts!!! I just found a spinner loose on a friends 6a.... I was pushing the aircraft around and the spinner felt loose... ACK! I looked behind the spinner without removing anything and saw it cracked 2/3 of the way around.... the crack was 1/4 in outside the shaft of the prop on the rear bulkhead... cato 3 blade prop. Caught that just in time! DO those condition inspections properly!!!! You'd be surprised what you find... Not to mention cleaning all the FOD out from the flight controls!
Best
Brian Wallis
AP/IA
