Inverted fuel tube stuck on pro seal
I had my tanks resealed this spring by Weepnomore and just discovered a serious potential problem. I was flying on my left tank, which was just under 1/2 full and the one with the inverted tube, when the engine started surging. I switched tanks which fixed the problem. After checking the vent and fuel lines, I unfortunately had to remove the tank(again) and open it up. Thats always fun. Anyway, everything looked normal. My guess is that the weight stuck on one of the pro-sealed screws at about the 1/2 full level. The weight had a blob of pro-seal stuck on it. By the time I took the tank off and rotated it, the flop was making it's requisite noise so it must have broken loose when I inverted the tank.
Anyway, just another consideration when sealing your tank with a flop tube.
