I'm curious about the clearance between the 45 degree restrictor fitting on the accessory case and the engine mount.
My O-290-D2 uses a conical mount and should be about the same case as an O-320, except for the mounts.
I have about an 1/8" clearance between the fitting in the engine mount and my fear is that the fitting will be knocked off as the engine moves around.
How close is your fitting?
Click on the picture to enlarge:
I have sent these pictures off to Vans to see what they think. It might be that the engine in a conical mount sits closer to those tubes than an dynocoal engine.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
