Old 04-07-2005, 05:23 PM
Alschief Alschief is offline
Thumbs up Damaged Gear Leg Axle Threads
I have an older RV 6 Kit.
While preparing to assemble the Wheels found the Axle threads damaged.
They are 1 1/4 " X 16 pitch.
I could not find a die anywhere locally to chase the threads.
I contacted Langair Machining the supplier for the gear legs.
They promtly, at no charge sent me a kit including the shipping.
What a great company.
They also have a program to straighten bent gear legs
Langair Machining Inc
503 397-1478
3309 Church Rd
Warren, Or 97053.
Al Smith
RV 6
N 495AB Reserved
Old 04-08-2005, 12:57 PM
dan's Avatar
dan dan is offline
Default Thread file
http://www.google.com/search?q=thread+restorer+file
)_( Dan
RV-7 N714D
http://www.rvproject.com
Old 04-08-2005, 02:28 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I agree with Dan on the thread file. Chasing with a die could do more damage if you cross thread it over the damaged threads. Using a thread file on the first two or three flights will correct them and then use a thread chaser die to clean up the rest.
Roberta
