Old 07-24-2014, 05:18 PM
kjlpdx kjlpdx is offline
Default my tilt-up latch system
I never liked the design on the tilt up. a lot of friction and off-centered torque used to pull the canopy down by jamming a cam thru a slot. this is my version which uses the arm rest as a lever and an over-center cam action. with the arm rest raised it is difficult to mistakenly take off with the canopy unlatched. as you can see I have been using this latch system for 15 yrs. if I made it over I'd make the arm rest lever a bit more robust in the left/right direction. one could possibly damage it if they grabbed the end while it was extended.
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
