07-25-2014, 04:56 PM
fugio ergo sum
I've burned up 3 or 4 strobe switches. My latest fix is to leave that switch on all the time. Working so far.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
07-25-2014, 05:33 PM
Originally Posted by rocketbob
Taking voltage readings at various points isn't a good way to troubleshoot.
Because...V=I*R.
If I (current) is very low, the few microamps of current passing thru the voltmeter with a high resistance R, voltage at the switch will read close to the battery voltage.
The real test is to disconnect the switch altogether and measure the resistance with it on. If its more than a few milliohms, it needs to be replaced.
Speaking of Ohm's Law, strobe power supplies are, like most switching power supplies, negative resistance devices.
What I mean is that as the input voltage falls, the input current rises in order to provide a constant output power. Any problems with the input power feed will lead to a thermal runaway... A bad crimp, a bad switch or breaker. Keep your eye on this at every Annual.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
07-26-2014, 09:46 PM
Voltage loss
You might find a partially broken conductor or if there is a termination(butt splice, terminal strip, etc) between the switch and the load a loose or damaged connection will actually become a heater. If a switch is going bad, you should derate the replacement.
07-27-2014, 10:00 PM
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
SWITCH!!!!! Thank you all  Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
07-27-2014, 11:01 PM
Forum Peruser
Glad you found the culprit, Rosie! Congratulations!
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
07-28-2014, 05:12 AM
I recently was about to tear into my Kubota diesel engine because it was cutting in and out during operations - some suggested check your seat safety switch.
That was an easy fix!!
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
