Old 07-25-2014, 09:22 AM
N402RH's Avatar
N402RH N402RH is offline
In the RV-7 the module is mounted on the sub panel with the fuses below the edge so you can get to them.
The module not only has a Skyview network hub, it will also talk on it to the EFIS displays. We will be adding more functionality to the EFIS interface in the future.
Yes, the module was designed to accept all the current radios that we already interface to.
I would argue that you should not be messing with fuses or circuit breakers in flight. When is the last time you had to change a fuse while driving in your car? Poorly designed and wired electrical systems cause breaker trips, solve that and there should not be a need to reset in flight.
There was an airliner that crashed on the way to Mexico a few years ago where the pilots kept resetting the trim circuit breaker until it was uncontrollable.
The module is also designed to work with the TruTrak autopilot.
Rob Hickman
Advanced Flight Systems.
Old 07-25-2014, 09:25 AM
Jrskygod Jrskygod is offline
For us that already have the skyview displays and modules will the wiring hub be available separately?
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 07-25-2014, 09:35 AM
N402RH's Avatar
This is still very new and we are looking at all options.
The big advantage to us providing a complete panel system is that we can test and configure it. This will eliminated many hours of frustrating troubleshooting and tech support for you and us.
Rob Hickman
Old 07-25-2014, 09:54 AM
N402RH's Avatar
Remote circuit breakers also add weight and complexity. You end up having to run a wire to a crimp ring terminal, screw the terminal to the breaker, screw another ring terminal to the exit of the breaker, and then have another crimp connection. That is a lot of failure points and weight.
Rob Hickman
Old 07-25-2014, 10:46 AM
grayforge's Avatar
grayforge grayforge is offline
Default Weight/failure points vs ease of install
Since weight and additional failure points were mentioned in this discussion...
The plug & play Control Module has a bit of compromise too: While the many Fast Stack style D-Sub Sockets and internal connection circuits make assembly fast and accurate, they do add a bit of their own weight and failure points vs running just the wiring required directly from component to component.
  • Up to 40 extra plugs (and additional failure points)
  • Unused circuits/wires
  • Extra length of wires going from Device A to Control Module to Device B instead of directly from device to device that may be mounted next to each other
But while a compromise, this is ultimately very cool for those who don't want to run their own wiring.
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 07-27-2014, 07:04 AM
BHunt BHunt is offline
Is there any thought of integrating Vertical Power products for there ECB's and other capabilities into the quick panel?
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 07-27-2014, 10:21 AM
cjensen's Avatar
cjensen cjensen is offline
I'm sure you are asking about integration with the Quick Panel system, but Vertical Power does integrate with AFS and Dynon. You just have to build the system or have one of our dealers build the panel for you.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 07-27-2014, 12:42 PM
Jackm Jackm is offline
Default Circuit data
One of the things we do inflight is to pull up the VPX on AFS Effis and scroll through each circuit and look at its status and amp draw. This info tells a story on each circuit and we feel is this to be very valuable info. Also the availability to override the panel mount switches and reset circuits has been used for testing purposes and provides redundancy. As usual, the more data and options we have the more we want
Is this new system capable of these features?
Jack Maljaars
Rv10
N819DJ flying. 350hrs +
Dues 2015 pd
Old 07-27-2014, 12:52 PM
Bill_H's Avatar
Bill_H Bill_H is offline
That horrific fuse access would make this a non-starter for me. Easy to blow a starter solenoid circuit fuse. Or want to pull a fuse for a variety of reasons during maintenance or troubleshooting on the ground. Fuses should be on a sub panel mountable through the main panel like the RV12.
Just one opinion! other than that - a winner!
Does it incorporate sound level and trim rate adjustment pots like the Vans AV-5000A box? If so I hope the adjustments are better and more accessible - the Vans design is quite poor in that regard.
Bill H, RV12, N412BR "Sweetie", Skyview-equipped, KASL Marshall TX
Old 07-27-2014, 01:21 PM
N402RH's Avatar
I think you will be very surprised how easy it is to get to the fuses in the RV-7. We have two RV7 panels with sub panel and ribs in the booth at Oshkosh so come see for yourself.
Each device has its own volume adjustment so there is no need to have an adjustment in the module. There are no potentiometers to adjust in the module.
"Easy to blow a starter solenoid circuit fuse" I have over 1900 flight hours (900 hours in the RV-10, 600 in the RV-4 and 80 in a Glasair Sportsman) and I have never blown a starter solenoid fuse.
Rob Hickman
N402RH RV-10
