Old 07-23-2014, 10:02 AM
Guilhermepilot's Avatar
Guilhermepilot Guilhermepilot is offline
Default Exhaust install
hello Captains
Just receiveD my vetheran Exhaust and my question is, assemble al pipes prior install, or during installation?
thank you guys
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
Old 07-23-2014, 10:47 AM
rzbill's Avatar
rzbill rzbill is offline
I have the Vetterman 4 onto 2 crossover exhaust for the IO-360-M1B.
It was easier to pre-assemble and then install on the motor.
In fact, I had to preassemble. The slip joints would not go together without a lot of twisting that could not be done with part of it bolted in place because of clearance issues.
If it were not for that, sure, a piecemeal assy in place would work fine.
Bill Pendergrass
ME/AE '82
Old 07-23-2014, 01:22 PM
cjhammes's Avatar
cjhammes cjhammes is offline
With my crossover exhaust, I found it easier to assemble during installation. Like every other task in building you will likely have these on and off a couple times so you can have the benefit of trying both ways.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 07-24-2014, 01:37 PM
I will assemble during install, thanks for the advise guys,
As a matter of fact, i sand it and polished it is bright!
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
Old 07-24-2014, 02:11 PM
N941WR's Avatar
N941WR N941WR is offline
When you install them for the first time (that's a hint), don't tighten the nuts down because you will remove and re-install it a few times as work on fitting everything to your engine.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-24-2014, 04:07 PM
Yes, that applies to the whole build process. Ny-Lock nuts on only finger tight, no cotter pins installed yet, etc. That's why TorqueSeal is so great?applying as the finishing touch is my favorite part.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 07-24-2014, 04:15 PM
Kahuna's Avatar
Kahuna Kahuna is online now
FWIW. I find on a new install. Install in pieces. Goes slower and lets you look and think about what is going where along the way. After your up and flying, on and off in one piece is much easier, in particular with Vettermans new tail pipe clamping method. Easier to leave all that together. There is no wrong answer either way. But you will be taking it on and off a number of times as others have mentioned. Dont tightening anything up.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 07-24-2014, 10:30 PM
aerhed aerhed is offline
Also, do yourself another favor. Apply a nickel anti-seize paste to all slip joints and cylinder studs.
Actual repeat offender.
Old 07-25-2014, 03:39 AM
N941WR's Avatar
Veterman's recommends using Mouse Milk on all the slip joints. I apply some every time I pull the cowl.
Bill R.
SC86 - Easley, SC
Old 07-25-2014, 07:02 AM
Definitely I love this forum and all help we have during
A built process thanks all
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
