Old 07-23-2014, 01:58 AM
rgmwa rgmwa is offline
Default Stabilator question
Has anyone done any experimenting at a safe altitude to see how well the pitch trim can or cannot control the -12 in the event of a stabilator cable breaking?
rgmwa
RV-12LR 912ULS
120346
Old 07-23-2014, 02:38 AM
Alex Edwards Alex Edwards is offline
If only one of the cables failed couldn't you use the trim to keep the other cable tensioned and still use the stick to control the stabilator via the still working cable?
Old 07-23-2014, 10:24 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
I,m just installing mine....each cable is really heavy duty. Can't imagine how you'd ever break one. Even if it rubbed on the tail section you would cut through a lot of aircraft before cable failure.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 07-23-2014, 11:29 PM
Fortunately cable failures are pretty rare, but they are not unknown. There was a fatal accident in Australia two or three weeks ago that has generated a lot of discussion down here and appears to have been the result of a control cable issue (not an RV). I understand that the FAR's require certified aircraft to be able to be flown in a stable attitude without the use of the primary longitudinal control system. RV-12's are designed to ASTM standards so presumably they don't need to demonstrate this behaviour, but it would be useful to know what would happen if one of the cables or linkages did fail, and whether trim and power could be used effectively to try to get the plane down safely.
rgmwa
RV-12LR 912ULS
120346
