Originally Posted by DanH
....and remember, none of it came from Sam.
Nope, I did not forget, but IIRC, you modified a standard cowl to go with round passages to the "engine cover" or non-cowl, plenum. I was not sure what his (OP) intention was, round or rectangular. I just though your work could either scare him away or provide inspiration to make his own plenum cover.
Actually, your high placed air inlets would seem to have an air flow efficiency advantage over the crank centered SJ ones as the "dam" at the front cylinders are reduced.
