Old 07-22-2014, 11:29 AM
gear1 gear1 is offline
Question IO360 fuel distribution instability
Some fuel distribution issues have been bothering me lately. After matching the injector nozzles, I have been operating lean-of-peak for a number of years with no problems. However, lately I have been experiencing some strange fuel distribution issues. The engine is an AeroSport Power IO 360M1 with Hartzell constant speed prop, Electroair ignition on the right magneto pad supplying spark to the top plugs, and a P-Mag on the left magneto pad supplying the lower plugs. A typical FF/EGT/CHT spread is:
Altitude: 12000
OAT: 58 degrees F
Fuel Flow: 6.7 GPH
CHT #1: 352? EGT #1 -47? (from peak)
CHT #2: 338? EGT #2 -54?
CHT #3: 372? EGT #3 -34?
CHT #4: 373? EGT #4 -32?
At times when initially setting the mixture for lean of peak, the distribution will split, with the #4 cylinder going much richer:
Altitude: 12000
OAT: 58 degrees
Fuel Flow 6.7
CHT #1: 375? EGT #1 -25?
CHT #2: 365? EGT #2 -55
CHT #3: 365? EGT #3 -45?
CHT #4: 385? EGT #4 -15?
The CHT and EGT seem to be in correspondence: EG- the highest CHT cylinder has the richest mixture as shown by the smallest drop from peak. The distribution seems random, and sometimes changes during the flight by itself. Sometimes going back to rich of peak, then resetting LOP fixes the distribution.
Does anyone have any idea what is causing this? Is it a case of dirty injectors or a problem with the flow divider? What might be the solution?
Thanks to all for your thoughts.
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
Old 07-22-2014, 11:40 AM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
The first thing you need to look at is your GAMI spread (fuel flow of the first cyl to peak vs the last). This will tell you how balanced your injectors are.
If they are balanced, then you could have ignition issues, EGT probe issues, or other things.
If they aren't balanced well, then you look at the fuel system.
--Ian Jordan
Dynon Avionics
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 07-22-2014, 12:28 PM
MarkW's Avatar
MarkW MarkW is offline
Hey Craig,
As Ian says the GAMI spread is more important than these other numbers.
I also suggest using https://www.savvyanalysis.com/home for a free service to chart your results. Very informative website.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 07-22-2014, 04:47 PM
jdeas's Avatar
jdeas jdeas is offline
Default Fuel divider
I'd consider checking the fuel divider and lines . If you have some trash or an obstruction in #3 it could manifest itself this way. This is a balancing act so fuel diverted from 3 could make 1 and 4 richer.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 07-22-2014, 05:05 PM
These number vagaries could simply be the result of a little chaos in the Lycoming world.
I'd try starting over from full rich and see if it is different. I bet it will be. These engines are not all that predicable when looking at numbers that closely.
There was a time when that was not possible or of consequence.
If the engine is running smooth and all else is normal, press on.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 07-22-2014, 05:16 PM
Kevin Horton's Avatar
Are these two conditions at the same throttle setting? On my aircraft, with IO-360-A1B6, I find that the cylinders reach peak EGT almost simultaneously, if I?m at full throttle. But, if I?ve pulled the throttle back a bit, I get a much larger difference between cylinders. I?ve never understood it, but I usually cruise at full throttle, so I haven?t worried about it much.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 07-22-2014, 09:10 PM
Red face Fuel distribution instability
Thanks everyone for your thoughts. For the record 1) all readings have been at WOT, 2) the gami spread is .2 Gph and 3) when the imbalance occurs, the problem can usually be corrected by going full rich, and then going back to Lean of Peak.
Craig Taylor
RV8 flying
Old 07-22-2014, 11:55 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
EGT imblance is not the point, but my observation is that if your spread is 0.2GPH typically, then this is good. But what you may be suffering from is an intake leak upsetting the F/A ratio's and some leaks for some reason are random in the amount of leakage from one time to another
Also I think your LOP ops should be yielding lower CHT and I figure you are running too much advance.
YMMV
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 07-23-2014, 08:35 AM
JonJay's Avatar
JonJay JonJay is offline
Although unlikely in a known good system, a contaminant could be "floating" around in the fuel divider. A buddy of mine had this happen. Symptoms where much more severe, a complete loss of one cylinder, from time to time, then a different cylinder, and so on. The piece of debris was large enough to cut off the fuel flow to the injector line, then it would move around after shut down. Sometime show up, sometime not. While it seems obvious, it was very difficult to troubleshoot.
I think this is a long shot but if you run out of things to check....
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-23-2014, 09:12 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Talk to Don Rivera at Airflow Performance.
I'm pretty sure it's the overall low fuel flow. At flows that low, the flow divider is playing a bigger part than the nozzles. Because I live at high altitude and routinely fly LOP at high altitude, Don had me switch all of my injectors nozzles to smaller orifices. This raises the fuel pressure at the divider and brings it back out of the equation.
I wouldn't do full power takeoffs on cold days at sea level because of this change, but I've never had the opportunity to try anyway. Landing at DA less than 6000' feels really strange to me.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
