Originally Posted by Kahuna
This is exhaust scavenging. Normal. The RPM does not indicate your level of power. The "Popping" can happen at any RPM, but it comes with a closed throttle, or very nearly closed. Most common with an injected motor and cross over exhausts, but is found on most any type.
OK, So it sounds like I might be in the same "closed throttle" categoy as everyone else, I just happened to trip that scenario earlier in the pattern?
That's comforting. Thanks!
