Old 07-19-2014, 12:06 PM
Luke D's Avatar
Luke D Luke D is offline
Default Heim LS-3 Bearings
Sorry this is not strictly RV related, but may also be of benefit to RV builders as well.
The RV-6 (7 and 9 too I would guess) uses Heim LS-3 spherical bearings as the pivot points where the stick assembly attaches to the spar (elevator movement). I'm considering using the same bearings in another aircraft.
My question is about lubrication. The specs for this bearing show a lubrication hole in the race along with a groove. The RV-6 plans don't show any provision for getting lubrication to this hole. Do most people squirt lube in from the side, or has anyone drilled a hole for this?
Luke Doughton
Classic Aero Designs
866.219.1087
541.926.7757
541.926.1373 fax
www.classic.aero
VAF Advertiser since 2003
Old 07-19-2014, 12:18 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Spray
Hi Luke,
I use greaseless LPS, with the red extender. Stuff a rag underneath the assembly and squirt. You can get to the fittings through the stick boot covers.
Usually inspect and spray during 25 hour oil changes.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 07-19-2014, 12:58 PM
Luke D's Avatar
That will work. Thanks Darwin.
Luke Doughton
866.219.1087
541.926.7757
541.926.1373 fax
www.classic.aero
