Originally Posted by jcoloccia
The type of load just has to do mostly with how the switch is pounded on when opening or closing the connection. An inductive load, for example, doesn't do didly to the switch when you close it, but when you open the circuit it'll try it's best to maintain an arc across the contacts. For this, you'd want a very fast acting switch with a large airgap between contacts.
..just my $.02.
John is right, even the lowly mechanical switch needs to be correctly specified for the application (voltage, current, type of load, environmental conditions, sealing, vibration.. and so on). Each of these factors will affect the design, construction and materials used in the switch. Spring tension, contact size, shape, material, hardness, plating and wiping action are but a few of the factors that go into the design of a switch. Some, like the chart in the aeroelectric link (a Microswitch TP series) are quite flexible. Other switches are specified only for DC (AT series) and others for AC only (TS series). When you go through a catalog, you'll see pages and pages of identical looking switches with different part numbers. There is a reason for that. Different loads present vastly different conditions to the contacts, closing AND opening, and the switch manufacturer will take the indended load and power supply into account when designing the switch.
Will an AC specified switch work reliably on DC? The answer is 'maybe'. In the FAQ section on their site, Carlingswitch says as a 'rule of thumb' you can use an AC rated switch in DC applications up to 30V. They should know. But they also have switches that are only specified only for one or the other. Does the same rule apply? Don't know. One series of 125VAC toggle switches may work just fine at 12VDC, even if its not specified. The problems can start when the manufacturer changes the design of the switch, has it made in another factory (adios Mexico, hello China) or it goes obsolete and the supplier replaces it with another 125VAC unit thats 'just the same' except not with DC loads but thats 'OK because its not specified for DC'.
For my money, I want to know that the manufacturer of the switch agrees with what I want to use it for. The only way to be sure is to consult the datasheet for the exact switch and make sure that its specified and rated for the load you are switching. That doesn't mean that you need 30 different switches, there are lots that handle a wide range of load types and voltages. If you are not sure, a short email to an applications engineer at the mfr is usually all it takes to clear things up.
From all of this, you can probably guess that I would also recommend buying the highest quality switches you can afford and watch out for the overseas stuff. The Japanese (Omron, Aromat et al) generally make great stuff even if it not made right in Japan. Chinese stuff is getting hard to avoid but at least try to stick with a known brand. Avoid no-name 'will-fits' at all costs.
As for the loose rivets, John is right again. Soldering is out. The switch was not designed to have loose rivets so if they do get loose, you have an application or quality problem. Maybe vibration or just a crappy switch. Soldering not only masks the problem but can introduce brand new ones from contact misalignment or flux wicking up into the switch.
Here's a tech blurb from Omron. Its about their snap switches but the same principles apply. Of particular note is the variety of contact configurations, gaps, materials etc and the DC switching performance (from Excellent to Inferior, in their words) for the different part numbers. All in a series of switches that are identical in external appearance. Different load types are also described.
Switch Info
OTTO T9 Toggles are fully specified (and expensive). Good tech info on their site.
McGill aint bad either - Note AC/DC specs.
Hope some of this helps.
John
