Wingtip landing/position/strobe lights
I'm trying to decide between a Duckworks light in each wing and the "normal" wingtip position/strobe light vs. putting them all in the wingtip ala the Airtech kit. I haven't been able to find if the Airtech kit Van's sells will accomodate all three, however.
There's also the RMD kit, which is pretty spendy, so I'd like to use the Airtech if possible. I just can't bring myself to cut into the leading edges of the wings for the Duckworks kit.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
