Old 07-15-2014, 10:15 AM
jpowell13 jpowell13 is offline
Default Tire weight
Just replaced the bald Aero Classic tires on the mains of my 6a with Monster Retreads hoping to get more life out of them. I've heard the retreads were heavier so I weighed the tires and rims before and after. The retreads are 7 lbs heavier. That's a pretty good hit to the useful load.
Nancy and I are preparing to make a trip from Baton Rouge to Idaho and will probably go sans main wheel pants since they also weigh about 7 pounds and I don't mind trading a little speed for baggage. Anyone else out there flying around without their pants on?
Old 07-15-2014, 10:35 AM
RVDan RVDan is offline
Default flying without pants
Occasionally, I do but I find that the seat belts can chafe a bit and other things get in the way of the stick.
Oh, I just realized you mean wheel pants. No, never.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 07-15-2014, 10:55 AM
krw5927 krw5927 is offline
The pics I've seen of Vlad's plane on his most recent trip show his plane "pants-less".
Kurt W.
RV9A
FLYING!!!
Old 07-15-2014, 11:58 AM
flyboy1963's Avatar
Default fuel for thought
...now this is NOT an endorsement to fly over gross......
however, the next thing I thought was......
weight drops by 7 lbs every 10 minutes of flight.
drag is there for the whole trip! ( without pants)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 07-15-2014, 01:06 PM
Dan, gotta save that weight where you can. Levis must weigh 3 pounds. And, much cooler without them!
sandpiper sandpiper is offline
If you are going to back country strips you might want to go sans pants.
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 07-15-2014, 01:22 PM
Ironflight's Avatar
VAF Moderator / Line Boy
You'l give away about 10 knots going without wheel pants -not important if you're only goign a short distance- but Baton Rouge to Idaho? That's a lot of hours! the other thing to consider is that coling goes up witht he square of speed (or something like that), and in the summer, out west, giving up cooling is a prolem for a closely cowled airplane.
Far better to keep the pants on (the wheel pants that is - we don't care what you do in the privacy of your own cockpit...) for the long trip, and fidn someplace to store them when you get out west before goign into the back country. They don't take long to remove, and there are lots of RV'ers around with storage space in their hangars.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-15-2014, 02:01 PM
ArVeeNiner's Avatar
Was the before weight the weight of a worn tire or a new tire? I would bet that the difference between a new and worn tire weight is significant.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 07-15-2014, 02:17 PM
I am sure you could find some RV people in Idaho that have tools and space to help your wheel pants while you hit the back strips. If you are in the Caldwell area, I will help you out.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 07-15-2014, 02:27 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
According to the specs, the Desser Monster retread weighs about 7 lb against 5 lb for a typical Goodyear 5.00*5.
On that basis you are only accepting a 4 lb weight penalty.
But a 5+% speed/range penalty is equivalent to about 2 gallons of Avgas. So filling up with 2 gallons less will save you more weight and give you the same range as removing the wheel fairings.
