I purchased a 796 that allows XM to be installed at anytime in the future but wiring harness dos not come as bare wire. I planned on connecting to Dynon D100 for A/P but there is no wires to hookup. Garmin what are you thinking!!. I made a slit in the wire leaving the mount and all colors are present except Blue. And there is another shielded bundle I assume to be for XM. Anyone know if There is a chance of using this harness or give Garmin another $60
I routinely caution people not to cut open Garmin pre-made cables expecting the extra wires to be there. I did this once and learned my lesson way back in the 296 days...
This is the cable you need:
Brantel (Brian Chesteen), Check out myRV-10 builder's BLOG
RV-7/TU, #72823, N159SB
Lyc. O-360 carbed, HARTZELL BA CS Prop, Dual P-MAGs, Dual Garmin G3X Touch Track N159SB (KK4LIF) Like EAA Chapter 1494 on Facebook
