Bobby Hester RV-10 Prop Balancing
Bobby,
We are very happy with the fine prop balancing job you did for us using your Dyna Vibe equipment. We no longer have vibrating door handles and there is much less cockpit noise during taxi, run up, climb out and cruise. This made a big difference for our simple painted interior, even with Lightspeed Zulu ANR's. Our IPS reading started at .24 with a factory new IO-540-D4A5 engine/Hartzell CS BA prop combo. We are now at .01! Cruise RPM= 2400. We will highly recommend you. Thank you!
http://home.newwavecomm.net/bobbyhes..._balancing.htm
Good judgment comes from experience, and a lot of that comes from bad judgment.
Reason: Corrected link.
