Dual master solenoids?
Working my way through Nuckoll's Z-13 wiring diagram.
I'm building an 8-a VFR with single battery, single alternator.
I'm not excited about the use of his "always hot" main bus because of the additional wire runs it would create from the buss mounted close to the rear mounted battery and difficulty accessing fuses for those wires.
I'd like to run all electrical busses from the always hot side of the starter solenoid (always hot when master solenoid is hot).
Given this scenario, it seems that the really significant system weakness is the failure of the master solenoid. I was thinking that a second master solenoid, with a separate wire and switch, wired in parallel at the battery, would address this issue.
Does this make sense or am I missing something obvious (or not so obvious)?
Tom H.
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
