  #11
Old 07-09-2014, 09:40 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default My very heavy wing
I just finished phase I on my RV 7a. Had a very heavy left wing, full right trim still rolled left. Incidence checked great. Re rigged all control surfaces which actually made the problem worse. Several small squeezes and flights and after 5 tries got it perfect. It how's flies hands off. The squeezes where so small that you can't even see where I did it.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 07-09-2014, 10:28 PM
rvbuilder2002's Avatar
Originally Posted by bajapilot View Post
Also, I still haven't been able to get a feel from anyone on quantifying the heavy wing. When stating they had a heavy wing does that mean that hands off the wing slowly dropped, very common on first flights. Or, like in my case, dangerously rolls if left unattended for more then a couple of seconds. I probably have a roll rate of 10 degrees/sec or better. It will immediately displace the stick several inches to the left.
That being the case, I strongly recommend that before you do anything else, you look at section 5.7 of THIS document and evaluate the shape of your flaperons, and correct them (based on the instructions provided) before doing anything else.
There is probably a lot of RV-12's flying that don't actually have the handling qualities the RV-12 is intended to have, because the shape of one or both flaperons is not correct (besides the strong effect it can have on roll trim).
Scott McDaniels
Hubbard, Oregon
Old 07-09-2014, 10:58 PM
RFSchaller RFSchaller is offline
Here's what my trim tab looks like.
http://tinypic.com/view.php?pic=zko38n&s=8
Old 07-10-2014, 05:35 PM
bajapilot bajapilot is offline
Default Heavy wing saga
So.... I went out to the hanger this morning determined to make some progress with my heavy left wing problem. I read all the ideas, tips and images posted by fellow builders. Read the document that Scott had kindly referred me to.
I have to say I wasn't optimistic because this was a very heavy wing and I was convinced that there had to be more to it than tweaking the flapperons. I examined the skins and at first noticed that some were not flat at the trailing edge but most were close - until I checked the bottom skins! I must have been lazy and not payed proper attention to them because there were many that had a significant gap especially on the heavy wing.
I went through each panel top and bottom and squeezed them with the tool shown in the Van's document. I could get most very close but sometimes getting one side perfect meant the other side open a little mid skin. Anyway, after doing both flapperons I did a quick test flight. BIG TIME DIFFERENCE! I still have a slightly heavy left wing but no auto slow roll. Where the stick would displaced 2 inches to the left, it's now almost not noticeable from vertical. Hands off it will still start a slow left turn but takes very little pressure to hold the wing up. From the cockpit where I could easily see the flapperons displaced they now look even.
So the bottom line here is once again when things don't seem right go back to the basics and read the book. I'm amazed at how much a small adjustment can effect the wing but now optimistic that if I keep at it I'll be able to get this balanced without the aid of a trim tab. I'll post on how this turns out for those interested.
Bill
Old 07-10-2014, 05:45 PM
JBPILOT JBPILOT is offline
Default Bill, one tiny tip - -
I have mine set so there is a very slight left turn BY MYSELF. With a 200# passenger, it slightly turns to the right. That is where I ended up, and like it. If I take my hands off, by myself, you have to look closely to see it slightly turn, so no big deal to me.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
Old 07-11-2014, 08:50 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Just to provide a point of reference, I probably adjusted my trailing edges 6 or 7 times to get it just right. First, I would do what Scott suggested and read up in the manual about it. Second, make small adjustments and go fly. It will take multiple iterations. Sometimes, you may go too far. I even blunted the trailing edge with a board and hammer to get it back. You can get it the way you want it but it's going to take some trial and error.
I found the best technique for bending the trailing edge is to take two long (approx. 6') 1" X 4" boards and install some hinges along the joint line. You are less likely to introduce a kink this way and you will get a more consistent bend.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 07-11-2014, 09:07 AM
bhassel's Avatar
bhassel bhassel is offline
I used a couple of pieces of alum angle from Lowes Aircraft supply. 1.5"x1.5"x6' duct taped together. It seemed to work great was light weight and cheap. Of course, I'm not flying yet!
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 09-12-2019, 10:38 AM
rv3flier's Avatar
rv3flier rv3flier is offline
This is an old thread, but after a tree fell on my hangar and damaged the flaperons, the flaperons were repaired. I had a pronounced roll to the left. I took it back to the shop that repaired the damage and they re-rigged the flaperons according to the plans. However, I still have a left roll issue.
RVBuilder2002 posted this: "That being the case, I strongly recommend that before you do anything else, you look at section 5.7 of THIS document and evaluate the shape of your flaperons, and correct them (based on the instructions provided) before doing anything else."
The link no longer works and his post doesn't identify "THIS" document.
Does anyone have a link or identify the document?
Old 09-12-2019, 11:35 AM
rcarsey rcarsey is offline
See Section 5.7 starting on Page 9 or so:
https://www.vansaircraft.com/service...d-revisions/5/
Rob Carsey, North Brunswick NJ
RV-12iS (N713)
Tail 100% done
Wings 95% done (AOA)
Fuse 100% done
Finish 100% done (cowl)
Avionics 100% done
Dues paid 2019
Old 09-12-2019, 12:14 PM
snopercod's Avatar
I have is a very heavy left wing.
Well, ya-know, the pilot sits on the left side. That in itself is going to make the plane roll to the left. I realize that the -12 doesn't have wing tanks, but in my Lancair, I always fly with 5 more gallons in the right wing to counteract my 250 lb. weight.
(2020 dues paid)
