Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #31
Old 10-11-2006, 06:13 PM
captainron's Avatar
captainron captainron is offline
Must be repeating myself! How'd that happen?
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 10-11-2006, 08:08 PM
frankh's Avatar
frankh frankh is offline
Default Yeah, yeah I get it now
Originally Posted by Kevin Horton
Sorry Frank, but you need to go back to physics class.
CASE 1 - extension in line with torque wrench
Let's assume you have your torque wrench set to 100 in-lb. Let's assume the distance between the hand grip and the square drive for the socket is 10 inches. If you put a socket on the wrench, and put it on a nut, you'll need to pull on the hand grip with a force of 10 lb to create a moment (torque) of 100 in-lb.
Now, let's imagine that you have an extension that is two inches long. You mount the extension so that it is aligned with the axis of the torque wrench, so the end of the extension is now 12 inches from the hand grip on the wrench. You put a socket on the extension, put it on a nut, and pull until the torque wrench clicks at 100 in-lb. How much torque have you put on the nut? The torque on the nut is the sum of two things:
1. The torque wrench applied a moment of 100 in-lb to the extension, and this moment is reacted at the nut.
2. You pulled on the torque wrench hand grip with a force of 10 lb, and this force is reacted where the torque wrench is attached to the extension. The 10 lb of force on the end of the extension creates a torque at the nut of 10 lb x 2 inches = 20 in-lb.
The total torque applied to the nut = the sum of 100 + 20 = 120 in-lb.
CASE 2 - extension at 90 deg to torque wrench
The 10 inch long torque wrench is still set to 100 in-lb. But now the 2 inch long extension is at 90 degrees to the torque wrench axis. We put a socket on the extension, put it on a nut, and pull until the torque wrench clicks at 100 in-lb. How much torque have you put on the nut? The torque on the nut is the sum of two things:
2. You pulled on the torque wrench hand grip with a force of 10 lb, and this force is reacted where the torque wrench is attached to the extension. This force is transferred through extension, and is reacted at the nut. How much torque does this force create at the nut? Well, the force is actually aligned with the axis of the extension. This is just like putting a wrench on a nut, and then pushing on the end of the wrench so that the direction of the push is directly towards the nut. You can push as hard as you want, and the nut won't turn, as the axis of the force is directly through the nut. The distance between the axis of this force and the centre of the nut is 0 inches, so the torque = 10 lb x 0 inches = 0 in-lb.
The total torque applied to the nut = the sum of 100 + 0 = 100 in-lb.
Actually I took about 10 mins sketching this out and decided indeed its not just the torque but also the force applied and the reaction therof.
The reason the extension can be ignored of course is that the effective is not the hypotenuse of the angle becuse the force is at 90 degrees to the torque wrench
It was not obvious though....Yup too long out of school
In short keep yer torque wrench aligned with the extension an use Dan's calculator...
Frank
Old 06-10-2008, 09:17 PM
ao.frog ao.frog is offline
Default Another converter
Hi.
I'm about to torque the prop bolts and found this handy converter: (when you need to put on a crow foot for example)
http://www.belknaptools.com/extcalc.asp
It works when the extension is less than zero too, just measure the actual length it adds to the length of the wrench (look at the pic and you'll know what I mean)
On the left side is a handy torque converter which looks like a calculator.
Nice for us metric guys who sometimes needs to convert into inches and pounds....
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 06-11-2008, 12:22 PM
Doug Rodrigues Doug Rodrigues is offline
Default Don't forget the Vaseline.......
From my past Air Force hydraulic/pneumatic shop experiences......you should smear a bit of Vaseline on the internal "O" ring inside the prop hub, just enough to make it slippery. Also rub just a bit of Vaseline on the end of the crankshaft where the "O" ring will slide onto. This will allow the the "O" ring to slide over the crankshaft end without causing any damage to that "O" ring. Chances are that the "O" ring wouldn't roll out, be pinched or cut, but the Vaseline would positively avert that situation. Better to be safe than sorry.
