Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 10-10-2006, 01:07 PM
RV_7A RV_7A is offline
Nope not true. An extension is an extension no matter how you look at it. Typical torque wrenchs that use sockets attached measure the torque at that specific point (center of the socket). If you add to the length of that point you would need to subtract from the actual torque setting to get the desired torque needed at the bolt.
www.JeffsRV-7A.com
N808TX
Old 10-10-2006, 01:23 PM
Steve Sampson Steve Sampson is offline
Default Moments!
Jeff, with respect, Marc has it right. Think about moments!
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 10-10-2006, 01:52 PM
frankh's Avatar
frankh frankh is offline
Default Not true
Originally Posted by MCA
An A&P friend told me that putting the torque wrench 90 degrees from the extension means that the torque reading is accurate and you don't need to do any calculations. If the torque wrench is parallel to the extension then you need to do some math.
Anyone heard anything similar?
Your still applying torque to the end of the open end wrench...Doesn't matter what angle you apply it...Dan Checkoway has a handy dandy torque extension calculator if you don't want to do the math.
Frank
Old 10-10-2006, 01:58 PM
I stand corrected...
-Jeff
www.JeffsRV-7A.com
N808TX
Old 10-10-2006, 02:04 PM
rv969wf's Avatar
rv969wf rv969wf is offline
Default You can borrow mine.
Originally Posted by RVPilotDotCom
Can anyone tell me what special tools ( crow foot wrench size... whatever ) I will need to install my CS Hartzell prop? This is my first and those bolts are very hard to get to, I can't even imagine what it will take to get them to the proper torque.
- Jim
Hi Jim, you can borrow mine if you need it. I machined it myself and it is heated treated and 1/2" thick, the calculations for torqueing are on the wrench. Let me know if you need to borrow it .
Alan (AJ) Judy
Beaver, OK in NO MANS LAND
RV-6 IO360A1B6 C/S Hartz 200HP ?
Also Fly North American NAVIONs
Race car engine builder/Machinist/Fabricator 1982--present.
Old 10-11-2006, 01:01 AM
Joey Joey is offline
Your A&P friend is correct.
I don't want to sound rude, but there is some very dangerous advice being given in here. Advice that could lead to people improperly torquing their propellers.
Absolutely incorrect. The angle does matter. If you require proof, this link does the math to demonstrate.
PLEASE be more careful with this stuff! I hope Dan sees this and adds a caution to his calculator that the values given are only accurate if the extension is kept inline with the tool.
Old 10-11-2006, 06:30 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is online now
Joey's comments are absolutely correct. The angle matters, and this is not ambiguous to those who has studied physics and engineering, no offense intended to those who haven't. The link he refers to might not seem clear to those who haven't studied that sort of thing, but it is correct. While it is often fashionable to bash engineers with comments like "what do they know, I'm the one trying to get this thing to work", there are certain things that should be respected. Bolt torque settings are not simply to keep the bolt from loosening.
Please trust us on this one -
BTW, here is another good option for a torque wrench in the mid price range (about $200 with a crow's foot):
http://www.mcmaster.com/ and then go to page 2673. Item 5347A24 plus the appropriate size crow's foot on the same page works very nicely.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 10-11-2006, 06:54 AM
This is good info Joey. I appreciate you guys bringing this to our attention. Its nice to learn something everyday. I stand corrected.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 10-11-2006, 08:27 AM
Jekyll Jekyll is offline
Yup, its in the FAA circular.
Jekyll
Buy the Circular
Read the Circular
Be the Circular
Old 10-11-2006, 09:07 AM
MCA's Avatar
MCA MCA is offline
Thanks everyone for the great info!
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
