Old 07-05-2014, 05:12 PM
dbaflyer dbaflyer is offline
Default Trimming small portions of plexiglass
When I made the big cut I gave myself plenty of extra off the front bow. Anywhere from 1/4 inch down to almost nothing to be trimmed. So yeah it is not exactly straight from the left to right side Is it better to trim this off using a cutting disc or with a belt sander? I have made all my other cuts using a diamond cutting wheel in a dremel. If a belt sander what would be the lowest grit paper to use?
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 07-05-2014, 05:20 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I used a belt sander, little tiny one with half inch wide belt, runs on an air die grinder.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-05-2014, 05:21 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Trim plexi
A vixen file is one approach that will stay cool, make a straight surface and give time to approach the finish line carefully.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 07-05-2014, 05:26 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've used a sanding disk on an angle grinder (small diameter) to get a lot of stuff off, then a belt sander with a moderately fine grit to get the final bit and make it straight.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-05-2014, 05:33 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I too found this to be the best after trying lots of things.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 07-05-2014, 06:17 PM
BillL BillL is offline
I used a 4" (wide not long) hand held belt sander with an 80 grit belt. Use a light touch along the length of the edge, and keep it moving. I marked the areas to be cut with a sharpie or could not tell what needed to be done.
I also used various lengths of mdf for sanding boards 4 to 12 inches long and worked down (up?) from 100 to 800 grit to polish the edges.
I worked solo so was not happy with the plexi flopping around so made a cradle for it.
PS - If you have a tip up, the front will pucker up when you snug the sides against the rails. Beware of trimming it too perfectly to early.
Bill
RV-7
Lord Kelvin:
