Old 07-01-2014, 07:16 PM
William William is offline
Default Bendix mag timing light questions?
Hello all I've got my Bendix mags mounted to the engine and I'm working on synchronizing the 2 together. The mags are part # S4LN-20 and S4LN-21. How do I hook up the buzz box to the mags? I've tried hooking the buzz box directly to the p-leads but to no avail, the buzz box does no buzzing or lighting. Any ideas what I might be doing wrong?
thanks,
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 07-01-2014, 07:59 PM
Is the key turned to 'both'?
paul mosher
Posts: n/a
Default buzz box
Please read instructions for the buzz box. Should be three wires. One to each mag one ground.
Old 07-01-2014, 08:00 PM
paul mosher
Posts: n/a
Default plugs
Also make sure you don't kill yourself, remove a plug from each cylinder.
Old 07-01-2014, 09:05 PM
cajunwings cajunwings is offline
Default Timing
Most of the timing boxes buzz when turned on and you can check the lights by touching the leads together. You might have box/battery/contacts trouble. Most also turn on the light when the points open. This seems backwards if you think of the mag as simple circuit with the points being a switch, but correct if you think of the light coming on and the plug firing as the same event.
Don B
RV - 9 Rebuild in Progress
Old 07-02-2014, 04:14 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Remove the P leads
from the Bendix mags and insert an adapter (I use a cutoff plug lead) into the p lead hole -- hook the buzz box leads to those -- works fine on my engine.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 07-02-2014, 05:54 AM
Yes the key is on both.
Finishing a RV10
Old 07-02-2014, 05:55 AM
I do have the ground clipped on as well to a good engine ground.
Finishing a RV10
Thanks Paul: no plugs are installed.
Finishing a RV10
Old 07-02-2014, 06:01 AM
Don B
Hmmm. Didn't test the box. I will hook the ground up and touch the left and right alligator clamps together and see if I get any lights or tones. The timing light I'm using is a tp-105.
Finishing a RV10
