  #11
Old 07-01-2014, 02:46 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Any info, photos or details for retrofitting this into an existing door? Wondering what has to be modified, removed, drilled to make these work.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-01-2014, 03:27 PM
J Twilbeck's Avatar
J Twilbeck J Twilbeck is offline
Mark,
I installed the existing handles with the Planearound third door latch first before installing this new handle. I also had the Planearound guides and latch sealed in with fiberglass prior to the test install.
To modify an existing door the existing handle mechanism needs to be removed to cut back the internal handle tube and it's internal pin. The Delrin block is replaced with a new one. The door hole you cut for the Vans handle is opened up to a larger diameter and an additional hole is drilled forward of that for the lock. All of this is covered up with that external ring in the end. Then the handle is reassembled in the pocket and screwed back into place.
If you have sealed in your external screws, things could be a bit tricky, but its not impossible. This is just a suggestion for someone in that particular situation. This is untested so I have no guarantee that it would work. But I would suggest drilling out the rivets that hold the nutplate to the internal plates (the one that is turned upside down for your external screws) then you can turn the nutplate to remove it allowing you to then remove the internal workings. Do the work on the door, like I mentioned above, then reassemble. The internal plates (C-1006A, B, D) are reused in this design. After assembly, screw the nutplate back on and use pop rivets to hold it in place.
I have written complete instructions for the install including a lot of pictures. I don't know if Aerosport is wanting to release the instructions yet, but you could give them a call. It wouldn't hurt ask.
P.S. You did a beautiful job on your plane!...I check out you blog for insight on a regular basis.
Justin Twilbeck
RV-10 N521TW
Flying!!
http://buildingrv10.blogspot.com
Old 07-02-2014, 10:13 AM
Zac@AerosportProducts Zac@AerosportProducts is offline
Post
For those that are interested in the Low Profile Door Handle, we are compiling a waiting list of interested clients.
We will be starting a production run in the near future. When we have them available, we will go right down the list of contacts in the order that we received interest.
We are currently unsure of what the final cost will be at this time.
I do, however, have the installation instructions available to those who would like.
Please contact me at Zac@AerosportProducts.com or 614-834-8659.
Zac Holcomb
Future builder of something, someday.
I live it through all of you. Thanks!
3DPrint@AerosportModeling.com
Old 07-03-2014, 10:20 AM
BenNabors BenNabors is offline
That looks great, very impressive! Working full time, building an RV, and designing and marketing a product - I am impressed.
Old 01-09-2015, 02:25 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
I would like to announce that Aerosport Products is now taking orders for the
new low profile door handles designed by Justin Twilbeck. Introductory price of $345.00. These handles come with everything you need accept for the ACS door locks. These can be purchased from Aircraft Spruce part #11-01600.
All aluminum is polished and all stainless steel. We will only be taking phone orders for the first 2 weeks then they can be purchased online. Orders will start shipping 1-19-15.
Contact Geoff or Zac at Aerosport Products for more information and ordering at 614-834-8659
See earlier post in this Thread for video's and additional info
Geoff Combs
http://aerosportproducts.com
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 01-09-2015, 02:34 PM
rocketman1988 rocketman1988 is offline
Default D'Oh....
You guys are killin me...more stuff to buy!
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 01-09-2015, 02:37 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Look good Geoff, couple questions.
What work (if any)is involved in replacing existing handles from finished planes?
Will they work with the PlaneAround center latch setup, which has a 180* rotation of the handle?
Thanks.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-09-2015, 03:18 PM
Aerosport1's Avatar
Mike they are very simple to install. I replaced my standard door handles with them. I recommend removing the doors but it could be done with the doors still on the airplane. As for the PlaneAround center latch they will work fantastic together. Either the 180* or standard.
Geoff
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
Old 01-09-2015, 04:00 PM
I can email install instructions to anyone that is interested. Feel free to reach out with any questions.
Zac Holcomb
Old 01-09-2015, 06:47 PM
hugo hugo is offline
Default Door handles
It's the price for two handles?
Hugo
