Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #31
Old 06-30-2014, 01:33 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by DeltaTango View Post
A friend had an idea of putting a push button type switch on the panel that would remove power to the Pmag during run ups. The procedure would be to turn one ignition off then press and hold the button. Should see no change in operation. Next turn the first ignition back on and then second ignition off and repeat the push button test.
Just a couple of ideas.
David
I considered a pushbutton switch then thought about there failure rate and went with the setup described above.
Just keep in mind that this is your ignition you are messing with!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-11-2015, 09:29 AM
Josef's Avatar
Josef Josef is offline
Default problem with ignition switch
hi there,
fired it up my P-Mags today and now I have this question:
I have the ignition switch from Van's Aircraft installed ( OFF - R - L - BOTH - START ), used that for the Slick magnetos. Now when I fired up the P-Mags strangely enough I can switch to right or left P-Mag, but when I turn the key to "both" the engine goes dead. Anything I overlooked in the installation manual ? Obviously I do have to change the wiring of the ignition switch ? Any advise ? Thanks a lot in advance !
best regards,
Josef
RV-8A / YIO-360-M1B / 2 x P114 from Emagair
