Originally Posted by barryrv10
I have an Electroair EIS ignition which uses wasted spark coils on an IO-540 and it has been great for 300hrs. When starting today I got what I think was an after fire (ignition on the exhaust stroke) just prior to a normal start. I can see this happening if conditions are just right; like the old days when we would turn the ignition off then back on and get a "backfire"
Since this is a first for me, has anyone else with wasted spark ignitions had any similar problems like this when starting. I did not have a kick back, just a loud firecracker like bang then a normal start. Thanks Barry
The EIS fires cylinders in pairs. A fouled plug in one cylinder can affect the spark in the other cylinder. If it fails to ignite, the unburnt charge may ignite during the exhaust stroke or in the exhaust. Check the plugs. If they check out, remove all of the plug wires from the coil pack and crank the engine. You should see sparks between the coil turrets. You may need a partner to observe this.
All of the coils should spark the same. If they don't, you have a bad coil. It's a GM Part, available anywhere.
