Refer to paragraph (19) of your operating limitations.
Change props, perform new W&B, logbook entry, place aircraft back into phase I for minimum 5 hrs.
This assumes that the original prop is F/P and your op lims are of the current version. Regardless, your op lims are the ruling factor.
Earlier op lims required a new airworthiness inspection. When were your op lims issued.
Call me if you want to discuss. 972-784-7544
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
