Old 10-03-2006, 07:43 PM
butch butch is offline
Default Aluminum V8 Power plant
I am needing some assistance. Two years ago, I recall reading an article regarding an RV6/7 with an aluminum chevy V8 as a power plant. The article was wrote up in Kitplane or Custom Plane magazine and it was a shoot out regarding this motor and a Lycoming 180. Is there anyone that can tell me the month and magazine this article was in?
Thanks for your help!!
Jim (Butch)
RV7
Ready to order finishing kit
Old 10-03-2006, 10:00 PM
cjensen's Avatar
cjensen cjensen is offline
Not sure about the Kitplane article, but you may be thinking of the Vesta V8.
Vesta V8
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 10-03-2006, 11:03 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The article was in Custom Planes and covered the LS-1 powered RV7 conversion by Predator Aviation. Nothing ever came of it apparently and their website does not mention much about it. Way too heavy for a -7 but if I remember, it would exceed redline in level flight at something like 22 inches and 3400 rpm probably making it the fastest -7 ever built. Climb was something crazy like 4000 fpm. It even had a/c for hot days. I don't think weight was ever mentioned though.
Interesting experiment but probably not too practical.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 10-04-2006, 06:33 AM
TSwezey TSwezey is offline
Predator Aviation is building two RV-10's with the Vesta V-8 in it. He has already received the engines. The LS1 is too heavy for use in a -7. It also has far too much power. I am putting one of the Vesta V-8's in my plane. We will probably have one of the fastest RV-10's. I am not putting it in for speed though. I wanted a/c and to run on mogas. I also wanted to climb out of any airport on a extremely hot day with out any problems. I fly a Grumman Tiger now and it scares that **** out of me on hot days and short runways with full fuel(Not anywhere near gross weight either.) There is also another forum here in which the V-8 was discussed in length by many. either Predator or I will be the first RV-10's to fly with this engine. Our goal is to be airborne and tested before Sun-N-Fun.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 10-04-2006, 07:05 AM
rv6ejguy's Avatar
Cool, keep us up to date on your -10 and the engine installation. Maybe we can compare numbers at 18,000 feet. (I know I'd lose at lower altitude.)
Old 10-04-2006, 11:29 AM
FlyerJumper FlyerJumper is offline
Originally Posted by TSwezey
...either Predator or I will be the first RV-10's to fly with this engine. Our goal is to be airborne and tested before Sun-N-Fun.
Yes, please keep us up to date. Lots of interest here also.
Mark
RV-10
On again, Off again Building
...currently Off
