Old 06-22-2014, 02:56 PM
DennisRhodes DennisRhodes is offline
Default IC A210 error message
Have a A210 that began having Rx problems couple days ago. Weak, Distorted and extremely low volume. I did see the RX flag over the freq when message was incoming, TX seems to be fine. Decided to pull from the tray and reseat the connector. The ribbon wire now looks to be damaged. On repowering up I get a "RX ERROR" message on the left side where active freq is normally displayed. A little wiggle in the tray and it will go away but reappears. Can the ribbon cable be the problem or is there something that needs ICOM attention??
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 06-22-2014, 10:30 PM
flightlogic's Avatar
I understand the cable is often the weak point. It can be replaced fairly simply. Call Icom USA on Monday. Report your progress if it works out ok.
Old 06-23-2014, 02:46 AM
eddieseve eddieseve is offline
It's the cable, stop playing with it and buy a new one before you damage your radio, new connector cables a cheap.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 06-23-2014, 03:42 PM
Default ribbon cable
Icom seems to believe the ribbon cable could cause the problem. I ordered half a dozen ribbon cables, they are $2.75 each from the west coast. Shipping to east coast is $7.00 and couple days. Hopefully I will have couple extras if anyone needs one.
DRRhodes
2020 VAF Supporter
RV9 N908DR
