I'm not a "guru" but I have done a lot of research and reading......
As I understand it, the first step is to set the max RPM with full static power to around 2550-2600. This is achieved by adjusting the fine pitch stop - finer = more RPM. Doing this assures that as you put power on at the start of the TO run, you don't over-speed the prop as the governor tries to catch up. Apparently, the factory setting should normally be right.
As the aircraft accelerates, the RPM will increase. At this stage the governor picks up control of the RPM. So this adjustment can only be done in flight. My MT manual says to put the aircraft in a slight dive at full power and watch the RPM. If it wants to go past 2700, then reduce using the prop control and leave it there for the rest of the flight. After landing, adjust the governor screw to the stop plate.
If you can't get more than 2680 no matter what you do with the governor, then perhaps your fine pitch stop is set too coarse so the RPM never gets high enough to wake up the governor. This would be indicated by a lower static RPM and you are effectively operating a fixed pitch prop.
I think all props/governors basically use these principles but I'm sure any genuine expert out there can put me right.
The 250hp versions of the 540 produce that at 2500rpm. So the extra 20rpm is worth about 1hp. I would suggest that in terms of risk assessment, it would be better to set the max at 2675 so as to avoid potential overspeeds/distractions at a critical stage of flight - but that's just me...........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Reason: Further clarification
