Old 10-03-2006, 07:10 AM
tvlawyer tvlawyer is offline
Question First 5 rivets - one "oops"
I put many hours into workin gon my tail this weekend and got to the point where I riveted the HS-411 elevator brackets around the Y-146 bearing. Using AN470 4-6 rivets, all were textbook except one looked rather short. I drilled it out and made sure to clamp the HS-411's tightly together before bucking another rivet. It was again too short. I can't figure out why the others are OK and the one is short. After drilling out two bad rivets the hole is somewhat enlarged. Should I use a larger rivet in there?
BTW - I primed the rear spar and reinforcement bars with Sherwin-Williams GBP-988 (thanks Dan Checkoway for the recommendation) The GBP-988 is a pleasure to work with. Goes on evenly and parts are ready to handle in about 15 minutes or less.
Old 10-03-2006, 07:36 AM
pierre smith's Avatar
Default Gauge
Hi Larry,
Sometimes, the wrong size rivet will find its way into the bag, so check them as you use them. Secondly, do you have a rivet gauge? Its a little device that you put against the rivet before you drive it to determine if it protrudes far enough.
Another trick is to make a simple gauge to see if you've driven the rivet enough: Since the finished rivet head should be 1.5 times the original diameter,, drill a 9/64" hole in a piece of scrap and a 3/16" hole on the opposite end. These are the finished diameters of the 3/32 and 1/8" rivets respectively. They should just fill the hole in the gauge if they're set correctly.
On your enlarged hole, unless it's really sloppy, use the same diameter rivet again,
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-03-2006, 08:32 AM
I bucked that rivet three times with the same result. It's too short and the shop head doesn't mushroom enough. The others turned out just fine. In fact, as measure with the little rivet gauge, they're damned near perfect. I can't figure out why I can't get this one rivet, in a circle of five (or is it six? I don't have it in fron of me.) to set properly.
The HS-411 is a small part, hard to buck. I think I'll wait until my pneumatic squeezer arrives this week and then try it again.
P.S., Pierre. Did I tell you I got a hangar at RYY? I had to buy the building and I will sublease it until it's time to put the wings on. But at least I found away around the 5+ year waiting list.
Old 10-03-2006, 08:38 AM
prkaye prkaye is offline
This sounds similar to the problem I had with the HS-911 brackets. The rivet size specified is very close to being too short, but it works if everything is perfect. One of the holes on that part ended up getting a bit enlarged when I made multiple attempts, and I think this slightly enlarged hole made it impossible to get the height of the shop head right (they always ended up too short). I suspect it's because more of the rivet material gets squished out to fill the slightly enlarged hole.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-03-2006, 08:42 AM
Brantel's Avatar
Brantel Brantel is offline
Default Try a little longer rivet
Try a little longer rivet to allow more material to fill the hole. If the hole is too large, you will neet to use an oversized rivet.
This hinge is really not needed soon so you can move on until you get your squeezer. You will love that thing when you get it. Make sure to get an adjustable set holder because that is what makes a pneumatic squeezer really great.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-03-2006, 10:36 AM
Brantel's Avatar
Default Will work Sometimes
It will work sometimes. Not for a grossly oversize hole but for a slightly oversize hole it will work just fine. Pre squeezing a little usually stops it from bending over.
Old 10-03-2006, 02:20 PM
TSwezey TSwezey is offline
Don't always follow the directions! If a rivet looks to short before you buck it, it probably is. As you get further into it you will realize the rivets they call for don't always work. Primer will sometimes create a small enough thickness change that will force you to choose a larger rivet.
You might want to buy a rivet cutter and some long rivets. This will allow you to cut to a specific size.
Sometimes you have to go drink a beer and come back an hour later! When you come back, you will be well rested and that one rivet will take you two seconds to do it correctly.
Good Luck
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 10-03-2006, 04:31 PM
Default Buy a bag of long rivets of each style and cut to fit
Even in military production aircraft drawings the notes allow for substitution of longer rivets to accommodate tolerance buildups etc. Pretty early in the process I bought a 1/4 lb of AN470AD4-10 rivets, AN326AD3-10 rivets and a rivet cutter from Aircraft Spruce to deal with short rivets. If the rivet looks too short ... it is too short. If it is too long it will clinch over and look horrible. You can generally squeeze a longer rivet satisfactorilly than you can drive and buck one. It doesn't take long and you should be able to judge what is right. I squeeze the rivets whenever possible but I use a mechanical (hand) squeezer from Avery that I bought in 1996. I believe it is important to develop as personal a relationship with the process as possible. It sounds like you know the theory and the general acceptance criteria but you are hung up on literal compliance with the drawing callouts. Sometimes the drawings are not correct for the application because of tolerance buildups or drawing error. I would take a rivet that extends through the material around 1.5 times the diameter of the rivet and squeeze it in place carefully and forget it if the installation produces a good looking rivet installation.
Bob Axsom
Old 10-03-2006, 07:02 PM
RScott RScott is offline
Here's a little trick you may want to try if you have a pneumatic squeezer; might be doable with a manual one. Works for 426 rivets, anyway; haven't tried it on 470's.
Take the next longer rivet. Mike it to check the length. Compare with the length of the specified rivet. You are going to shorten and fatten the longer rivet.
Put rivet set for a 470 rivet in the yoke opposite the ram. Adjust the squeezer to close to a length about halfway between the two (you do have an adjustable ram, don't you?). Set the rivet in the squeezer (hold the thing upside down with the rivet on the end opposite the ram to keep the rivet from tipping). Carefully squeeze the rivet. Now you have a rivet that is a little shorter and fatter, so it will cover the longer distance needed and will fill the hole better.
Old 03-07-2008, 01:55 PM
designerX designerX is offline
Question how much of a beating can the HS-411 take?
Now that I'm done with the practice kits and have moved on to the real deal the 4th rivet I set needed to be drilled out. I too think the rivet call-out in the plans is too short... unless somehow the primer on my VA-146 added another half mm
I had to energetically beat on the 411 with a hammer and punch to get the rivet out. I ended up using 470AD4-6 for 3 of the rivets. I'd advise anyone else just to start off with this size (or atleast check for the 1.5 diameter length instead of just going by the plans.)
Additionally I decided to just order a new 411 assembly because I wasn't comfortable with the amount of beating required to get the bad rivet out.
Stan
Stan Smith
RV-8 slow build fuselage w/showplanes fastback
RV-4 (bought flying)
