Old 06-18-2014, 04:12 PM
s10sakota's Avatar
s10sakota s10sakota is offline
Default Basic Lycoming leaning?
OK, I bought a Piper Cherokee to fly while I build my RV. Yes I know it will slow the build progress but I'm ok with that.
It's been 17 years since I've flown behind a Lycoming, but I have a 10 hour flight next week from TX to MI to bring it home. If I remember correctly we used to lean Lycomings by slowly pulling the mixture until it started to run rough, then push it back in about 100 RPM.
Of course there are more precise ways of leaning but there are just basic engine instruments in the ol Cherokee.
I just want to make sure I'm remembering correctly and that this will work as a very basic way of leaning the engine?
Thanks!
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 06-18-2014, 04:41 PM
db1yg's Avatar
db1yg db1yg is offline
Default Piper Leaning
A Cherokee 180 was my first plane--flew that old beast for 5years. Sounds like mine had similar instrumentation--little to none!
I leaned to engine roughness, then enrichened until smooth--worked fine!
Hope this helps.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 06-18-2014, 04:45 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Hope this helps.
db
After everything I've read on this subject that's still about the best advice there is. Unless you have fuel injection and great instrumentation it will do you just fine.
If you want to get technical:
http://www.avweb.com/news/savvyaviat...g198162-1.html
Old 06-18-2014, 04:50 PM
mike newall's Avatar
mike newall mike newall is offline
Yep - Crack on.....
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 06-18-2014, 05:07 PM
turbo's Avatar
turbo turbo is offline
you will be making some fuel stops. check your gal/hr at fill up to see what rate you are using. this will help verify leaning setting.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 06-18-2014, 05:35 PM
s10sakota's Avatar
Thank you!
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 06-18-2014, 06:32 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
I lean by watching the tach rise while turning the mixture out and then twisting in one full turn when the ram's start to drop.
Old 06-18-2014, 06:55 PM
brad walton brad walton is offline
Completely of subject, but Turbo thanks for all the great pictures!
Old 06-18-2014, 07:12 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Mike Busch has some excellent leaning webinars on the SAAVY analysis site also on the EAA site.
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 06-18-2014, 08:06 PM
xblueh2o xblueh2o is offline
That is pretty much the way I did it when I had no engine instrumentation beyond oil pressure, temperature and tach.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
