06-16-2014, 05:32 AM
Plane Power Standby Alternator?
My electrical plans call for a Plane Power FS1-14B backup alternator (yes, I know it's not the "backup" version they sell). My new engine has a ECI 90 degree oil filter adapter. On the Plane Power website, there is a statement that that "An ECI, Caspar Labs or B&C 90 degree oil filter adapter using a spacer in excess of .75" may conflict with the installation of this alternator". My spacer is well over 3/4".
Is anyone using this unit (or even the B&C unit) with a 90 degree oil filter adapter?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Reason: Clarification
06-16-2014, 05:57 AM
I have the ECI 90 deg adapter with a B&C 20 amp back up alternator installed with no interference issues.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
06-16-2014, 06:38 AM
Thank you Walt. Any idea how thick your spacer is? Mine appears to be 2-1/2"
www.marksrv8.com
06-16-2014, 06:48 AM
Not sure, its the original one that came from ECI with the engine kit if that helps.
06-16-2014, 07:02 AM
I'm using the same setup as Walt, with NO spacer, mine works fine.
06-16-2014, 08:01 AM
Same here. No spacer, IO-375, no issues.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
06-16-2014, 08:06 AM
Well, that's the point...I do have a spacer and I'm hoping that some with a spacer like mine will chime in. I know the ones without spacers work.
www.marksrv8.com
06-16-2014, 08:20 AM
Here's a photo of the back of the engine with the gigantic spacer...
www.marksrv8.com
06-16-2014, 10:34 AM
For those with the 3/4" spacer, do you have any issues with the oil filter clearing the engine mount? What size filter are you using? Thanks!
www.marksrv8.com
