What I did
I used the "pop" rivets in my -4 but bonded it with PRC first using the pop rivet holes to cleco together the tubeframe/canopy/skirt until bond of PRC was cured. I then removed clecos,and installed the pops "wet" with PRC to get a good tight seat. I work with PRC and Proseal daily in the heavy aircraft industry, and to clarify, they are fairly identical,just trade name differences. The -4 canopy/skirt would be a challenge to get fit with only a bond process due to the aluminum skirts not seating without the clamping of the clecos. PRC will last forever, and I would put it up against most any adhesive.
Bill E.
RV-4/N76WE
8A7 / Advance NC
