Old 06-14-2014, 09:27 AM
Stepclimb Stepclimb is offline
Default Connecting Manifold pressure lines
I hope someone can help me with this. My existing Manifold pressure line is 1/4 in nylon tubing. I am installing an insight G3 analyzer which has an AN-2 male flare fitting. Normally AN-2 would connect to aluminum tubing of 1/8 in OD.
I can tee off of the nylon tubing and run 1/4" OD nylon tubing to the insight G3, but I'm stumped on how to connect the 1/4" OD nylon to an AN-2 male flare. After searching Spruce for options, I can not find any elegant solutions.
Any ideas ( perhaps with part numbers from spruce or others)
Thanks!
Old 06-14-2014, 09:31 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Drew, welcome aboard the good ship VAF
Are you using the primer port in a head to source your manifold pressure???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-14-2014, 09:52 AM
Thanks Mike!
I'm not sure what you mean about a primer port. From the Lyc IO-360, I've got 1/4 " Nylon tubing running to my analog MP instrument.
I see several manufacturers make brass tee's for 1/4" nylon, but I can't figure out how to get 1/4" nylon tubing to mate to the male AN-2 flare on the back of the G3 instrument.
I had thought of putting together an AN-2 nut and flared 1/8" aluminum tubing, but the 1/8" OD aluminum is considerably smaller than the ID of the 1/4" nylon.
I don't want to introduce a leak in the MP sensing system.
Old 06-14-2014, 10:05 AM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by Stepclimb View Post
Thanks Mike!
The primer port is where the brass fitting with copper tubing is attached in this photo.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 06-14-2014, 11:08 AM
Ok..now I see....in my setup. .the cylinder fitting is 1/8 NPT to AN4 45 degree elbow then 1/4 aluminum tubing...then when it enters the cockpit, there is a fitting that converts from AN4 flare to 1/4 in nylon tubing. The easiest tubing to access under the panel is the 1/4 OD nylon.
I just can't find an elegant solution to join 1/4" OD nylon tubing to a male AN-2 flare....
Drew
Old 06-14-2014, 12:21 PM
Larco's Avatar
Larco Larco is offline
Thanks!
Take a look at this. Larry
http://www.aircraftspruce.com/catalo...lickkey=194657
Old 06-14-2014, 12:36 PM
Toobuilder's Avatar
... I had thought of putting together an AN-2 nut and flared 1/8" aluminum tubing, but the 1/8" OD aluminum is considerably smaller than the ID of the 1/4" nylon...
I'm guessing that the AN fitting is not simply threaded into the G3 analyzer with NPT?
So how about using some heat shrink sleeve on the -2 aluminum hard line so that it makes a nice snug fit inside the 1/4 inch nylon. A couple turns of safety wire as a hose clamp should seal it up nicely.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 06-14-2014, 02:23 PM
jay.pearlman jay.pearlman is offline
Rather than a conversion to Nylon, can you run aluminum all the way, using a bulkhead feedthrough at the firewall. Think carefully if a failure or leak in the tubing will cause a failure in one of the cylinders.
Old 06-14-2014, 03:00 PM
Originally Posted by LARCO View Post
Hi Larry,
I saw that tee, but was concerned that the description mentioned that the larger two barbed fittings were for 1/4" ID fuel line. My nylon MP line is 1/4 OD with .050 wall. I don't think the nylon is flexible enough to stretch that much.
Old 06-14-2014, 03:07 PM
Michael,
Thanks! I had not considered heat shrink, but that might just do the trick.
For the life of me, I don't know why Insight used an AN-2 male flare. It would have been easier if it was female NPT. I have not tried to remove the AN-2 fitting. I am concerned it may have sealant on the threads or a nut on the back(inside the instrument)that I don't know about.
Instead of safety wire, I might use 2 small cable ties to cinch down the nylon over the heat-shrinked hard line.
